luckyluke
- Aug 12, 2012
- 39
I have a 470 mercruiser s/n: C658976 and want to change the temperature sender and gauge. There is only one terminal on the sender so that leads me to believe the sender uses the block as ground (non-floating). There are two wires connected to the sender terminal. I assume one goes to the gauge but where does the other one go? They appear to be tan in colour; one has a blue stripe. They both disapear in the harness and I would like to know where the "other" wire goes.
Thanks
Luc
Thanks
Luc
