Re: 1982 Mercury 90 hp loses power no top end
Good thread... having the same issue with same outboard right now. Started a compression test, got to the third cylinder when the battery started to die... expected as this battery is upwards of 5 years old. Anyways, the third cylinder was about 10 lbs lower, with the first two checking in at 124 lbs. By researching, it leads me to believe if it gets worse, there is a gasket problem or possibly piston ring problem. Any insight? Links to helpful threads maybe? Anyways... just as a quick reference... what would you rate a piston ring replacement/ head gasket replacement at on a scale of 1-10 with 10 being impossible? Thanks for the help guys, and moodman be sure to change out as much as you can before you get into the deeper factors. Start with the fuel lines, primer bulb, filter, gas, spark plugs, plug wires, etc... see what you can change in your garage before you see what you can pay the repair man!!! (even though he has to make a living as well!!!)
