I have a 65 9.5 Johnson that will not rev all the way up at wot, ou can hear it kind of pop and go alittle faster then slow up some then speed up againits only a very small amount though. It has new coils, new wire, plugs, points, and they are @.02 getting, plenty of fire. Also the motor will rev higher if I turn the low speed(rich lean knob) needle to only a 1/4 turn from seated. If I go a full turn or 1.5 it will idle good but top end suffers. I have adjusted and readjusted the points checked everything I can think of the carb has been rebuilt new float ,needle, seals, gaskets. Also the primer bulb is not staying tight but it will run allday like that and it doesnt help to pump it while going, doesn't run better with good off either. Please help I'm sick of this motor!
