Greeting All Experts;
I think I visited here last year for help which was very informative. My problem is I refurbed all that is usual; points, condensers,coils, carb kit with new plastic float. Cleaned carb and all passages. Float is set level with gasket when upside down. Spark jumped 1/4'' gap, compression 75+ on both.
Last week I managed to get it running with a little shot of mix into the carb throat. Ran it in the tank for about 45 minutes to set the high and low speeds. WOT was very responsive and slow speed would not go down all the way to the SLOW mark on the handle but it was idling very good at the slowest I could get it. Next day started up again without help, let it run until it was warm enough. Tried to start yesterday (about 5 days later) on its own, no go. I noticed fuel dripping out the carb under the choke plate. Pressure tank is all new top housing, push button model. Fuel in glass bowl also, new mix proper ratio. I didn't write down my High and Low speed needle positions, sorry for that. So, what do I need to do to get her running unassisted. Any advice greatly appreciated.
Donald
