jbabcock
- May 22, 2010
- 50
Hi i have a15 hp 1986 evenrude it was over heating i just replaced the head gasket and water pump housing slip plate and impellor i dont think its overheating anymore i ran it with both muffs and barrel noticed the barrel after about 2 hrs of running it was at a slow trickle but this might have just been from the barrel becoming hot as the water did heat right up as well i noticed more water comming out the exaust and was just wondering if that is normal and should it have water comming from both the exaust and the pee hole?
