evinrude 70hp idle mixture adjustment
bodybag
Hi, have a evinrude 70hp 83 that runs great apart from needing a blast of choke when throatling up if i dont then she will just die on me, also needs choke to start if it stands more that 5 min or so. thermostat appears fine and engine tempreture appears to be about right. no air leaks that I can find (T Piece) and carbs have been sinked, I been told that these run lean, can I adjust the mixture to richen it:confused::confused: up a little to see if this helps? greatfull for any advice.:confused::confused:
boobie
Re: evinrude 70hp idle mixture adjustment
There are no dle mixture screws on that mtr. Only fixed jets. Sounds like it's carb cleaning time.
