southwest395
- Apr 30, 2012
- 137
Hey everyone have a couple questions?
1. When i pulled my plugs they smelled like the motor was runing rich ? The carb was just rebuilt.
2. How to make sure it is timed right ?
3. I want to make sure my shift cable is adjusted right. Prop spins freely in neutral left to right. But when i shift it sound like its slaming in gear. All the gears look good teeth wise and not alot of metal shavings on the magnut on the fill plug on the outdrive. There alittle but not much. Is that normal to have some ?
4. whats the recomended rpm at idle and rpm at runing speed ?
