Hi,
I have discovered that my transom is rotten in my boat, so need to remove the engines and drives in order to replace the plywood in the transom.
This is the first time I will have removed an engine from an outdrive boat, so its all new to me.
I have a couple of questions:
1. The 6 bolts to remove from the sterndrive sheild are very rusty and I think its going to be a job to remove them all with a socket. If I was to grind the heads off would I have sufficient thread protruding afterwards to remove them once the engine is out? I would be replacing the bolts anyway due to the condition of them.
2. I have heard there are some seals that must be replaced after removing the engine installation. What & where are these seals?
Any tips are mucho appreciated!
Regards,
Louis
Regards,
Louis
