Tilt problem with mercrusier 3.0
treble569
HI,
I am having a problem when tilting/trimming. Going up is not a problem, but when powering to go down the Z drive does not move.
If I put engine into gear and start driving and then try to tilt down the Z drive goes down and will work fine without any problems at all. once stationery again if I tilt up, it will not go down unless I put it into gear and drive again.
Can anyone help with this problem??
Thanks
Jamie
Malta
