Re: 76 15hp evinrude wobbles a lot
If you look at the exploded diagram at this url
https://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1976&hp=15&model=15655A&manufacturer=Evinrude§ion=Exhaust+Housing
The parts that control the motor "shake" are the rubber mounts- #4, 5(need 2), 41, and 82. Any or
all of them could be contributing to your problem. To replace them you need to remove the gearcase,
then take the powerhead off the midsection casting and take apart the parts that hold these rubber
mounts in place, and replace them. If they're all bad (I just picked up an '88 where they are all bad),
it's $210 for the parts. I've got a "parts motor" I'm going to get them off. Or you could look on E-Bay
You should also read up on this in "LeeRoy's Ramblings"- a wealth of information about these
engines.
http://www.leeroysramblings.com/#12_OB
He explains the teardown and replacement of these mounts. He also shows a
cheap repair to the "5" parts, which can cost $60-80 each. For the details of that, look
at the article on Powerhead/Midsection repairs, about 2/3 of the way through the article.
