best operating temperature
wayne nicol
i have a 2 stroke 110 hp johnson-J110 TLCUR.
what is the best running temp.
i have just replaced the water pump , after it was overheating.
i will be testing with one of those laser hand held temp gauges .
what distance should i hold the laser from the cylinder head when i test it- i have noticed that distance does effect the result.
thanks
wayne
Bob_VT
Re: best operating temperature
About 128 degrees but that is the water temp. Have you changed the thermostats? The deflectors? The water pump is only part of the equation.
It is only necessary to post your question once and not in multiple locations.
wayne nicol
thanks bob
sorry abouyt the multiple post- new to this forum- see now how it works thanks
havn't replaced deflectors or thermostats .
the overheat was from picking up some kelp.
the o/b mechanics at the johnson dealership said that a water pump running dry can ruin the water pump- so i changed that first.
could the "kelp" overheat cause damage to the thermostats and deflectors too
thank you very much
wayne
oldman570
Yes damage to the stats and other parts can happen in a overheat situation. The amount of time the motor was run will have alot to do with just how much damage was done. The shorter the time the less damage. If it was quite some time the motor will fresse up and alot of damage can be done.
Oldman570
boobie
Hold the laser about 8" from the top of the block just before the cyl head. Do both sides. About 125* at idle and no more than 160* at WOT.
wayne nicol
tthanks all
ran it and highest temp i could get was 145, at consistant high revs, for extended periods of time.
so problem seems to have been rectified
sincerely thanks all, for all the help
wayne
