casper5280
- Jul 19, 2003
- 11
I had a Volvo Penta 280 leg that is leaking oil in to the drive shaft bellows. After inspecting the leg oil I found it was all milky. I removed the upper and lower gear case and replaced all seals and O-rings and pressure tested it. Ran the boat a couple times and checked the oil and again water in the oil. Pulled the upper gear case and had water in the bellows and a nice white milkshake. I replaced the O-rings in the upper gear case and pressure tested it and it held pressure, I didn't have a vacuum gauge so couldn't test it Ran boat about 10 hours and checked leg oil, again all milky pulled upper gear case and found that there was a seal for the drive shaft in there that I didn't replace as it was all rusted over and didn't even know it was there. Replaced the seal and O-rings and tested it again held pressure. ran boat again about 10 hours and checked oil again all milky. Drained all oil out again and pressure tested it. 15 lbs and the leg held it all day long. Went and bought a vacuum gauge and it will not hold any vacuum at all. I have tried to find the leak and can just not find where it is leaking from. I used a very small amount of silicone on all the seals and the drive shaft bellows when repairing it. I've got the repair manual for it and there is no info on finding vacuum leaks other then spraying heavy oil on it and watching for it to be sucked in. Pressure leaks was the soapy water test, and no bubbles as it held pressure. I'm thinking that it might be the drive shaft seal but how would you see if it was leaking when its all covered up with the bellows. Also is the a seal where the shifter cable enters the leg? I see just a backing plate and 2 bolts. Again nothing in the manual about seals there. Any help is much appreciated, thanks Casper
