I have a 1991 Mercruiser Alpha Gen 2 drive that came in two pieces from its previous home. it was apart for a water pump replacement and the man had a heart attack. The problem is that the water tube and connections from the lower unit to the upper are missing. I cannot seem to locate the propper fittings to remedy this problem. I looked on marine wholesale and there are several water tubes but im really not sure what it used to look like as this is my first project . I hope that you can steer me in the correct direction as far as what I am looking for.
Thanks
Dan
Thanks
Dan
