tonynoriega2
- Jun 26, 2012
- 114
Hey all...
I wanted to go over my first steps to get some insight into best practices... I have been digging through the forums for days on end now to see what works, and what does not.
SO... a few questions here.
Taking out my transom wood. I think I am going to drill out the rivets, and replace them with stainless steel nuts and bolts. Are the rivets a standard size? Is it 3/8"???
The rivets holding the ID tags on the hull seem to be the only ones that look rusty... common problem? They look to be smaller than the hull rivets. When I remove the tags, repaint, and replace them, should I patch the holes or try to rivet in the same holes?
I have no paint on the interior or exterior of the boat, but plan on giving it a good sanding down to get a nice surface to bond to the primer and paint. No real dents or bumps that I feel need to be addressed...just some gouges in the gunwale.
Is there a recommended grit of sand paper I should use? I also hear that using the sand paper wet is best, true?
Obviously I am not worried about the finish, since I plan on painting it, inside and out.
Which leads to this question... there seems to be some gritty, as a squid, I once called "non skid" in the bottom of the boat, and rides up the sides just a few inches.... should I leave that alone or just wire brush it to clean it out a bit?
Thanks guys...
Thanks guys...
