Hi Guys,
My first post, and I am frustrated!
This outboard runs great except.... I cant get the idle right.
Carb has been disassembled and properly cleaned several times...
The engine will only idle well at 3 turns out... which seems really rich... and even at 3 - 3.5 turns out I can get it to sneeze by quickly revving it up from idle. It wont even idle at 1 1/2 turns out.
If it sneezes and stalls.. it is then hard to start.
The only thing I see is the gasket between the bowl and carb body seems to be leaking slightly, but this should not affect the mixture...
Any ideas...
Thanks in advance.
Any ideas...
Thanks in advance.
