cipherswitch
- Jul 16, 2012
- 1
I recently picked up a 1997 Citation by Sea-Pro (196 Royale CC). Its a 19 footer, on an all aluminum trailer w/torsion bars. I picked it up for a whooping $320.00. The bad, well the engine wouldnt even crank, after a good rain and noticing the 12 inches of water under the engine I had to redo all the bilge pump wiring and hoses w/ a new float switch .I determined the starter was bad, due to no crank and I figured that much water had been there before given that the old starter was damn near rusted solid. So I matched up part numbers and ordered a new one. I mounted it up and no dice, the starter clearly tries to crank the engine but it sounds like the engine is seized. I found alot of water in the oil (milky) and am now trying to determine just how bad the situation is, any advice?
