Delta22710
- Apr 18, 2012
- 20
1984 Force 85 HP
Hooked up to the garden hose, starts great, idles great, shifts into gear nice and snooth --- sounds awesome.....
In the water, starts after the 3rd or 4th crank, idels OK (sputters once in a while), put it in gear --- bogs and dies or sometimes just stalls right away. Can never get to WOT, even at low idle speed in gear it vibrates a little and then dies.....
Replaced gas tank, fuel line, fuel filter, spark plugs. --- no different.
Im thinking its the idle adjustments on the carberator and also the Throttle stop screw on the side. So my question is, How is this done? Should this be done in the water or out? In gear or in neutral?
Im new to boating and kind of mechanically inclined so go easy on me.
Thanks
Thanks
