Bass Tracker with Tracker Pro 50 HP power problems
kippisdad
My Uncle has recently purchased a Bass Tracker with Tracker Pro 50 HP motor. Today, when coming back in from fishing, we were running at full power and on plane, when we got a horn sounding from under the dash board, and then all power went away. No electrical to the motor, ignition switch, accessories, no raise/lower of the motor, etc. The trolling motor is on a separate circuit and battery, and operated properly. I am new to boat/motor electrical problems, but I looked at all the fuses I could find, and none of them were bad. I did not have a way of testing the continuity on the wires themselves, but all connections were secure...we simply had zero power from the battery to the switches or the dashboard. I am also not familiar with the horn that sounded, so any advice on what that was, and or any pointers as to what I can do to get this boat back in running order would be extremely appreciated.
NYBo
Re: Bass Tracker with Tracker Pro 50 HP power problems
Welcome to iboats!:cool:
The horn is likely the overheat warning.
There separate electrical systems for the motor and accessories. There should be a fuse or circuit breaker within a foot of the positive battery terminal on the smaller of the two cables attached to the terminal. This is for the accessory fuse panel. There is also probably a fuse or breaker under the motor cowl for the motor circuit.
kippisdad
Many thanks...he did go through a couple of areas of shallow water and dense foliage so it is quite possible he sucked some up into the intake. I looked at the inline fuses, and they were ok but I did not open the engine cover or check the relay switch, so I will check those when I get back over to the boat, and let you know how those checkout.
kippisdad
