How much test water do I need in tub to run outboard
GLE3
I have a 72 100HP johnson that I want to run in a tub/barrel The tub I currently have can only full the water up to where the lower unit starts (just above the cavitation plates). It is considerably above the intake where I normally put the flush when running on a hose. Is this ok to run or do I need the water further up?
Silvertip
Re: How much test water do I need in tub to run outboard
If the water intakes are fully covered and don't vent while running you are good to go.
GLE3
By venting I'm guessing your talking about air getting into the intake rather than water?
