Quick question. I have a 1989 Force 15 hp outboard. Got it cheap from a friend and it looks amazing. I gave it a tune up with the carb, (rebuild kit and fuel bowl had a hole in it, so replaced it). After breifly starting it, it didn't have a tell tale, so i shut it off and now i'm stumped. Ive also replaced the impeller when i was working on it, so now i'm puzzled. So my question is, should the water pipe ( the pipe exiting the water pump) be free flowing of water/air from the water pump to the exit of the tell tale? I currently have the lower unit off, and have tried to blow air and water into the bottom of the water pipe, and it does not exit from the tell tale. I have tried to run a small, but sturdy wire up through the water pipe, and from the tell tale end, but it still will not pass air or water. Also tried brake/carb cleaner through both ends. I have also cranked my air compressor up to 120psi, and tried to blow out any obstructions from both ends, but it has not worked either. I'm not sure if there's something obstructing the path or what the deal is. So once again, to sum up my question, should water/air be free flowing from the exit of the water pump, then cool the engine, then exit through the tell tale? This is my last resort before i hook up my 3000 psi pressure washer and give it a last ditch effort on full blast. Wife is already mad and telling me to throw the motor in the trash because i spend too much time on it, haha. Any help is greatly appreciated, because another day or to and this motor is junk.
