Is this boat going to kill me?
barfly5432
:eek: finally restored my johnson 15hp for my 13.5 fiberglass boat. Took it out and it is scary on this bought. i weigh 250 lbs. This boat has no problem getting me on plane but when it does it starts slamming up and down n the water I can actually feel the fiberglass flexing like a wave. is this normall. will it even out. should i reinforce my boat
Georgesalmon
Re: Is this boat going to kill me?
Porposing? Slamming up and down? The bow? If so tuck your motor under a bit more, and/or get some weight up front.
can you take a picture of back of boat (stern) dosnt sound like motor sitting deep enough.
barfly5432
short shaft on 18" transom. I will take pic. be right back
Home Cookin'
any boat can kill you if you don;t know what you are doing.
Put some weight toward the bow (front) including your 250# self,since you don't have a battery or carry much gas with a 15.
southkogs
What HP is the boat rated for? Maybe you're overpowered.
Bob_VT
Did someone remove a seat? It appears that the boat has allot of unsupported hull sides and yes that can kill you. You need to wear a PFD at all times and have the kill lanyard hooked to your vest.
Woodonglass
Motor Shaft is correct length. Hp is prolly at the top of the range for a 13 footer. Like George says make sure you're running the motor with her tilted in all the way and locked down.
halfmoa
Ensign
Kill switch bother, kill switch.
Ayuh,.... Agreed,.... It looks flimsy, 'n over-powered with that 6hp in the picture....
A 15hp on my Mirrocraft 12' tugboat would be a White-knuckle ride,.... with the 7.5hp, it's Very trim sensitive...
'n a White-knuckle ride,... if ya want it to be....
Have ya tried different trim settin's,..??
Howard Sterndrive
I have a 12' f/g like that too - rated for 6hp
put a 5 on it - will barely plane but controllable
put a 6hp -will barely plane, hard to control
put a 7.5 on it - death machine - cannot control it.
now it has oars
barfly5432
Thanks all. took wife on boat WOT pushed us along nice but the boat felt flimsy. you can actually see the slight v-hull push up and go completely flat on plane. going to beef up and move seat up to center with a pulley rope stick steer.
Captain Caveman
Agreed, there doesn't seem to be any support in the center of the boat. Is that how you bought it?
In any case, just because you've got all 15hp doesn't mean that you need to use it. It's only going to be scary if you push it to scary speeds.
rogerwa
Is that a homebuilt hull? It looks like some of the stitch and glue designs that use 1/4 plywood encased in FG.
You could also put a seat/support in the middle and use a tiller extension handle to bring the weight forward.
barfly5432
yeah I bought it that way. It had seats and other things removed before I got it. I was looking for a hull I could build my way. Does anyone know any sites to help me beef this wimpy boat up?
rogerwa
Are you sure it is FG? it may be plywood with an epoxy resin coating and FG and a resin paste on the seams. You could build a seat that sits in the middle to add rigidty using plywood supports that conform to the hull shape. You would attach this to the gunnels and bottom via FG strips, and a misture of wooddust and epoxy resin. then top the frames with a plywood or other seat base coated in the resin.
Search on stitch and glue boat building and you will find resources on this construction technique.
kfa4303
Banned
Probably about the max hp, but it should be fine, assuming the hull is sound. If you're 250# and alone in the stern with the motor and gas, etc...that's way too much weight in the rear. You can use a tiller extender (mine is made of PVC) to move forward in the boat and/or add ballast to the bow to even things out a bit. The anti-vent plate on the motor should be level, or slightly higher than the keel of the boat. Trimming the motor in (towards the transom) will help keep the bow down, while trimming it out (away from the transom) will raise the bow. You'll just have to do lots of trial and error to find the best set up.
Solittle
Don't really need another site - add a seat in the middle - that should tighten it up. I would glass the seat supports to the side of the hull and fasten the seat to the supports securely.
