I've got a 1985 mercruiser 170 with a burnt up regulator so I've purchased and installed a 65 amp 3 wire Mando alternator. Positive main charge wire hooked up to solenoid post where battery wire is attached. Exciter wire to positive side of coil. Sensor wire to positive battery post. Grounded alternator casing appropriately. She starts and runs and seems to be charging appropriately any where from 12.5 to 14 volts, but the alternator gets too hot to touch after a few minutes. Charge wire is barely warm, belt seems to be aligned and isn't really warm when I shut it down cause the alternator is too hot. Any ideas?
Doug
Doug
