I have a 1979 9.9 Johnson short shaft. The top of the cylinder head temperature reads 170-180 degrees after a few minutes of full throttle operation. The exhaust cover side of the engine reads the same. The telltale is hot to the touch, not scalding. The telltale stream isn't very strong, the exhaust shoots water out like crazy. The motor starts and runs well the whole time, the telltale cools to lukewarm at lower rpms. I replaced the water pump and there was no change. The head gasket was replaced last year and at the time the person who replaced it took out the stat saying it wasn't needed on this motor. So my questions are A) is this motor running too hot and B) if it is running hot what are the things I can do to fix this problem. This was my grandfathers motor so I would like to keep it running as long as I can. Thanks for the help.
