coreyallen40
- Aug 7, 2012
- 3
It had been 4 years since my last water pump replacement so I decided to do thermostat at the same time. The motor has worked fine for the last 5 years since I've had it, water has always come out quite strong from the pee hole. I have read pretty much all of Leeroy's rambling's during these past five years.
I hooked everything up same as last time: grommet is definitely in the copper tube, key is definitely in the impeller. After the first reassembly I hooked up mufflers, no water from pee hole. Took lower unit off and hooked up garden hose attachment to copper tube, now strong flow from pee hole. Reassembled, thinking maybe I messed up, same thing second time, no water from pee hole. Next I took water cover and thermostat out, hooked up mufflers, no water through water cover or pee hole. Disassembled, cleaned, reassembled 2 more times, just bcuz I thought I might have screwed up. Still no water from pee hole, or at thermostat. (also tried running with no thermostat, no difference).
I also hooked the lower unit up to the mufflers while it was separated from the motor and not much water came out the top of the water pump. Most of the water came out of the 2 drain holes on the lower unit, and also from the holes on the side of the water pump housing. I tried running it to see if that would help, but shut it off quickly so I didn't damage it.
I used to be able to get water from pee hole with mufflers on even without the motor running.
I have disassembled and reassembled this thing 5 times today, hoping to get out on the water, but I'm at my wits end. If I wasn't blad, I'd be pulling my hair out. The only thing I can think of is the kit is faulty (both water pump kit and thermostat are brp johnson parts from **********)
HELPPPPPP!!!!!!!!!
HELPPPPPP!!!!!!!!!
