Question regarding running 2 batteries on a pontoon. My plan is to use one battery solely for starting/engine and then switch over to 2nd battery to run stereo when floating/swimming and running inflator/deflator. With that being said, I also need to install a inverter that is connected to the 2nd battery to run 110v. Our inflator/deflator is 110v turbo that inflates to 3.0psi and runs off 110v, so I will need to spec out an inverter to run that. I assume I will need
battery switch--I was looking at the blue sea 9002e
http://bluesea.com/category/78/1/products/9002e
I am looking for inverters...I am thinking in the 1500watt will run the inflator
I have been looking at Xantrex inverters.....
and of course some cabling to make the connections.
Did some searching and have seen some diagrams, some are really complex and more than we will ever have for a setup and some are very basic. I just want the way to not damage any electrical components and no risk of fire.
Thanks
Thanks
