1purpleranger
- Aug 28, 2008
- 9
i bought a pontoon with 1990 evinrude 88spl on it and took i directly to a repair shop for rough idle an dhard start. they pulled t-stats replaced with washers, and put in new water pump. i know they didnt fix my problem and the pump needed to be replaced so whatever. i still have rough idle almost stumbles untill it warms up then it will start and run fine. after eight times out the overheat alarm started going off and i had no water whatsoever coming out. how long does a pump last?? how hard are they to replace yourself?? im a diesel mechanic so tools and general know how are not a issue. just my first outboard ive messed with
