Re: out drive lower portion leaking oil
The "port" sounds like the water pump drain<br /><br />As far as fixing it it could be leaking from the upper or lower drive and weeping out of the hole<br /><br />Your going to need to pressure test the drive to find which seal is leaking.<br /><br />Hows the oil look when you drain the drive ? clear or milky with water <br /><br />tommays
