Mercruiser 3.0LX 1997 starter mounting
artprofessor
Hello, as you can see in this picture of the solenoid and starter motor, might engine does not seem to have the standard long bolt/short bolt mount. There is a metal spine running the length of the starter that I have not seen elsewhere. I am wondering how to remove the motor from this mount. thanks.
Bt Doctur
Re: Mercruiser 3.0LX 1997 starter mounting
Look again ,there should be two bolts under the starter.
Ayuh,.... That's the extra front support strap,...
The other 2 bolts are where they oughta be...
