how do i empty waste
browny1111
i have a 1997 crownline with a porta potty fastened down in it's own are of the cuddy.
it has a vent host and a waste hose plumbed into it.
i don't see a pump or any way to drain the waste
the hose for the waste goes to a drain on the side of the boat marked "waste" and has a cap like the feul cap .
can someone tell me how to drain the porta potty without removing it ?
shrew
Re: how do i empty waste
Your going to need to get a "Pumpout". Many marina gas stations will offer a pumpout service. They have a hose they will connect to the Pumpout deck fitting and suck the contents of the holding tank out for you. Depending on where you boat, many towns have a mobile 'pumpout boat' that will come around and do the same thing. Pumpout boats will frequnet that towns mooring fields, anchorages and marina's.
It really depends on where you boat. Id start with a=n on-water gas station and simply ask them for a "Pumpout".
Thalasso
If you trailer your boat i think if you can find a RV park/camping grounds they usually have them free of charge. You then would need an adapter to fit your outlet to there hose. Marinas already have the fittings.
shrew
I would double-check this. It has been my understanding from conversations with RV'rs that those are gravity fed systems, not a suction based system. Not owning an RV i couldn't say for sure, so it is certainly worth checking out.
Thalasso
You could be right, and probably are. I just know there are some camp sites that have them. Don't know how they work. But it's worth checking out.
Home Cookin'
hope you're asking because you're curious and not that you need to know soon!
SotRH
This is absolutely correct. I've owned several travel trailers and an RV... and been in many parks. An RV's holding tank simply has a dump-valve with a hose attachment. The "dumping stations" are really nothing more than a hole in the ground (that leads to a sewer/septic system obviously) to run your hose into and a water hose nearby to rinse out the holding tank and hose. It's all gravity-fed, no suction.
acarter92
Yea, I've done lots of camping and never saw anything other than this.
Austin
browny1111
Thanks for all the help
I better plan a way to suck it out before i use it.
JoLin
The local marine pumpout station at a marina, fuel dock, or (in some areas) a mobile pumpout boat are your only options. It's illegal to dump it on your own unless you change over to a true porta-pottie and carry it home with you, which is what I'd advise. My last boat had a setup like yours- the toilet held a whopping 2.5 gallons of waste. IMO it was a worthless PITA that was a lot more trouble than a true portable toilet.
My .02
