I have a 16 foot, 1986 Fisher aluminum Bass Boat. It has a 1987 Mercury 35 hp two cylinder motor with a 15 pitch prop. The carb and fuel pump have recently been rebuilt, new fuel lines, new plugs and the timing set. Compression on both cylinders is 130 & 132 psi. The boat is really slow out of the hole. With the motor trimmed out and two adults top speed is 18 mph [gps]. The boat is rated for a 40 hp maximum. If this is the best I can get from the 35 I am thinking of going with a 50 hp. Would a different pitch prop get me up on plane better and would it be worth the investment? If so, what prop do you recommend?
