zoe'sdad
- Aug 15, 2007
- 116
So far I have changed the oil in the lower unit, cleaned the carburator changing the gaskets and hoses and yesterday I changed the impeller. After re-attatching the lower unit, I went to connect the linkage but the coupling and lower rod did not line up. I pushed the linkage rod down in order to connect the coupling. Needless to say the the motor will not engage in any gear now. Do I disassemble the lower unit or do I disconnect the linkage at the coupling and shift the gear selector to what ever position the gear is in when the linkage is in the down position and reconnect?
