Hello fellow forum members.
I am hoping you can shed some light on my dilemma?
Warning ?. long post.
I have a love/hate relationship with my 2008 Merc 3.5 - 4 stroke outboard. Well to be honest I don't love it at all ?. but I digress. I bought it in 2009. It is used exclusively on my little sailboat to get in/out of the harbour. That's it. Very short running time. Sometimes if the wind goes slack I have to motor in but in reality it isn't used much. I might go out a couple times a week in the summer months. I live in the Pacific northwest so summers are short. It is laid up for the winter from approximately October to June. So all in all it has had very little running time since purchase, but for such little running time, it has had, (and still has), a lot if issues. It just doesn't run well period, and never has from the get-go, but from my research into the subject some of that may have been my fault? Although I do rinse it every time after use in fresh water, I haven't been draining the carb. Also, I have on occasion been using older (but not ancient) gas. I am not very mechanically inclined with motors but I am now retired with time on my hands and I want to learn. I want to be able to fix this motor as best I can or at least get it running correctly, or I will have to get rid of it. It just isn't reliable. I live a bit remote and taking it to the dealer is both expensive and time consuming. I want to learn the basics and do things myself. I am sure many of you can appreciate that mindset? Since I don't have a mechanical background I have to do the research and ask questions on forums like this in the hope that some individuals will shed the knowledge I need. I "think" at the juncture that I may need to clean the carb? I am not sure what else is causing these problems?
So a small bit of history?.. last year, it would run for a bit then stall. It was impossible to restart until about 5 minutes had passed. Took it to the dealer (under warranty - whew) and it was deemed that the valves had carboned up?? What, how could this be after literally less than 5 hours total running time??? Anyways after 4 MONTHS in the shop it was finally repaired (the head gaskets were on back order). This left a very tainted taste in my mouth about Mercs and their turnaround time for repairs. And yes, once opened up they said the valves were gummed up and gave themselves a pat on the back. I still don't know why that happened? So now, this summer, it is acting up again in a similar fashion, but of course I am now out of warranty. Wah. It is not stalling after a few minutes of running but if I stop it for any reason I can't restart it for at least 5 minutes. It will stall on occasion. Yesterday, for the first time since I've owned it, I went for a long motor trip 1.5 hrs each way steady running. Again, if I stopped it, 5 minutes to wait till restart. After this trip I noticed the oil was very dark in the inspection window. Today I changed the oil (it was black, not sure why), replaced the plug, emptied the gas tank completely, put a mix of gas and SeaFoam in, and ran it. It did start and seems to idle fine but here's the issue. If I give it just a "titch" of throttle past idle it seems to cough and wheeze like it wants to stall. It sort of kicks into the next level of having more gas and seems to run ok at higher throttle (this is all in the fresh water bucket not on the boat). HOWEVER, if from idle, I QUICKLY turn up the throttle it STALLS EVERY TIME ???? It restarts on one pull at idle speed (no choke required) and it coughs, wheezes, just past idle as described before, and it still stalls every time if I gun the throttle quickly past idle.
SOOOOOOO ?. what is wrong ????
I am willing to take a shot at cleaning the carb (bit scary for me but I think I have seen enough videos to take a shot). Also, I do not know how to properly adjust the jets? I am hoping there might be a couple other things I can try before I need to do the carb? I am toying with the idea of buying a replacement carb so if I screw up the cleaning at least I will have a running motor with a new carb and I can just take the old carb into the shop to let the $70/hr guys put it back together. It's expensive to do this though, but I would learn.
Thanks in advance and sorry for the long post.
PS: I have 2 Honda Generators and a Honda Commercial direct drive lawn mower. They start every time usually on one or two pulls and run perfectly. They sound great. they have never let me down. Just like engines should, but this little outboard motor has been such a P.I.T.A. for me. Exactly the opposite of what I need, "reliability". Please, help me fix this thing?
Oh ... I forgot to mention how delightful it is to try and reconnect the plastic linkage between shutoff valve and red lever underneath. What a piece of design concept that is ???
