1988 Force 50 Starter issue
Lilylayne
I have a 1988 Force 50hp outboard. I am having issues with the starter not firing regularly when I turn the ignition. To date I have replaced the ignition, the neutral lock and the starter solenoid. I have also verified that the kill switch is good. I also fully charged the battery to make sure that was not the issue. I thought it might be the starter, but when I jump the solenoid it starts right up. Randomly the ignition will work and I think the problem is fixed only to have it not work again. Any suggestions? For what it is worth, the choke on the ignition works all the time.
scottmm73
Re: 1988 Force 50 Starter issue
Does the wiring from the battery have in-line fuses? If so check em for corrosion and if found clean em up. Don't know if it was coincidence but I just had the same issue (89 Force 85HP). Haven't had the problem since.
Lilylayne
Are you talking about the two pole fuse that looks like a Lego? (please pardon the bad description)
scottmm73
Looks like this:
jerryjerry05
The neutral safety switch adjusted right?
Loose connection?
If the circut breaker/inline fuse was bad it wouldn't start at all.
Under the dash,there is a fuse panel.Try cleaning the contacts on all the fuses.
Lilylayne
Loose connection?
Thanks. I did check the neutral switch by manually holding it in to see if that was the issue. I agree that I must have a bad connection somewhere between the ignition and the starter, as sometimes it will actually start. I am not sure if the fuse were blown it would start at all. I will check the fuses and connections and clean them well and tighten them down. Since the choke works everytime, I am thinking it must be a bad connection somewhere in my starter wire (yellow).
