bassindaUP
- Jul 4, 2011
- 5
I put new coils, points and condensors in the motor and when I tried to start it I got nothing motor will not crank over (starter not engaging). I got 12v from battery to starter solenoid. 12v from key switch to small terminal at starter solenoid. I don't know if I'm suppose to have voltage or ground from the starter starter solenoid other small terminal to the cut-out switch? 0v coming out of solenoid to starter. I believe the starter solenoid is junk, am I right to think this? I also checked the 2 power wires for the coils (M terminals at key switch) and got zero volts with key in the on position, does this mean my key switch is also junk. All other terminal on the key switch read right as far as voltages. Any info would greatly help.
