calling all johnson gurus
keefyc
hi folks ive recently purchased a johnson outboard with what i think is a faulty cdi unit but im having trouble finding any manuals or parts for it ! just comes up with model not found ! i cant find anything with the model number ! the model number is J25BALCIM can anyone help me with info on this engine ? pls . . :confused:
tx1961whaler
Re: calling all johnson gurus
1981 25hp Johnson
J = Johnson
25 = hp
BA = AC lighting circuit, Rope start
L = 20 inch shaft
CI = 1981
M = model run M (means nothing really)
woody66912
Post ser#.
Your right TX but that mod# wont come up on dealer port. The B's don't come up till 96.
Just get the part # off the power pack that's on the engine now. As in part #581927. or do you have a under the fly-wheel cdi.
F_R
I notice you are in UK. When searching for parts, are you looking in UK dealers? That motor probably was only sold in the European / UK markets, explaining why you can't find anything on it in USA.
tx1961whaler
Shows up fine in my list.... :)
25BACS / 25BALCS 1980
25BECS / 25BELCS 1980
25BFCS / 25BFLCS 1980
25ECS / 25ELCS 1980
25RCS / 25RLCS 1980
25TECS / 25TELCS 1980
25BACI / 25BALCI 1981
25BECI / 25BELCI 1981
25BFCI / 25BFLCI 1981
25ECI / 25ELCI 1981
25RCI / 25RLCI 1981
25TECI / 25TELCI 1981
25BACN / 25BALCN 1982
25BECN / 25BELCN 1982
25BFCN / 25BFLCN 1982
25ECN / 25ELCN 1982
25RCN / 25RLCN 1982
25TECN / 25TELCN 1982
25BACT / 25BALCT 1983
25BECT / 25BELCT 1983
25BFCT / 25BFLCT 1983
25ECT / 25ELCT 1983
25RCT / 25RLCT 1983
25BACR / 25BALCR 1984
25BECR / 25BELCR 1984
25BFCR / 25BFLCR 1984
25ECR / 25ELCR 1984
25RCR / 25RLCR 1984
25TECR / 25TELCR 1984
keefyc
thanks guys great help ! AC lighting circuit ? is that what the black plug on the side of the casing is for ? what voltage does this generate ? also how hard would it be to adapt it to charge a battery ? thanks
Silvertip
Unloaded the voltage may measure 20 - 25 volts or so. Make/purchase a rectifier and it can charge a battery at between 12.6 and as high as 16 - 17 volts at wide open throttle. The issue with a small motor is that they also have small alternators so the amount of "current" (amperage) they output makes it questionable as to whether or not it will serve a useful purpose as a charger. AC can be used for lighting so no rectifier is required. It cannot be used for battery charging without the rectifier.
