I just got a 06 Sun Tracker with a Mercury 90. Its been sitting for about 1-2 years and im having two problems and I feel like one of the problems may fix if the other is fixed.
Problem one - Engine turns over but wint start-
I have done the following:
Changed the spark plugs and gapped correctly
pumped out most of the fuel and added 5 gallons of premium fuel with a cleaner additave
removed the fuel filter and only inspected it and sprayed in some sea foam and replaced
pumped the primer bulb and opend the air valve on the gas cap.
Checked the plugs to make sure its firing
Ensured the kill switch tether cord is in place
Still not starting....
Problem 2
When I turn on the key it appears im not getting power to the following:
fuel gauge shows empty
Accessory switch, aeriator switch and safety light switch wont light up, nor will the horn work. Aeriator pump doesnt come on either. Nothing is connected to the accessory switch.
Stereo will not power up
Checked all the fuses and the breaker at the battery and fuse block and there all good.
Checked to see if power is getting to the switches and there is.
There are actually 2 hot (12v) going in the horn switch and to the horn.
Still no power. The lights on all the gauges work and the volt gauge is reading. Trim up and down on the motor is working.
There is a metal plate on the gas tank with two wires going to it and they are both hot (12v)
Can anyone help me to find the magic switch so we can crestin this poor mans yahat. Its late and I cant spell tonight. Thank you.
Problem 2
