crittertrapper
- Aug 3, 2012
- 2
So, my lovely Wife buys me a 1997' Reinell Rampage powered by a Merc 4.3 V6. We take it out to the lake and put 16 gallons of fuel in it, (does'nt even put us at a quarter tank....hmmmm...odd) we pull the kids around Alan Henry for two hours and this thing is running on fumes. What the heck? We smell gas...hmmm...not good. I trailer the boat and come home a little disappointed in how much fuel this beast uses and pull the plug to drain the little bit of "water" I saw under the motor at the ramp. As it's draining, I notice how stong the fuel odor is and think, "surely this is'nt fuel pouring out of my new boat?!" Stuck a stick in the stream....walked FAR away from the boat and lit the "water" logged stick...WHOA!! You guessed it....thats where all my fuel went. Tank is a 25 gallon aluminum tank that is mid-hull, under the fiberglassed in floor. Great. Not paying two-three grand to have the tank replaced...I'll fix it myself, right? Cut a perfect rectangle over ther tank, it's fiberglassed in...right against the hull. Did'nt feel confident enough to risk a hull breach cutting it out....so, I cut the top of the tank out thinking I'll mount a smaller tank inside it. Two pencil size holes in the bead of the tank, by the way...right at the forward end, at the bottom.
So, I order a 17 gallon Moeller marine tank, did'nt fit....because of the fill-neck...end up mounting it port side of the motor. Hook up sending unit, vent and fill lines...fuel line to my filter/seperator, patch floor, everything looks great. We head to the lake...splash the boat, start it up and putt to the dock....dies. for some reason...not getting fuel. Hour back to Lubbock....turns out, my fuel pump is'nt getting current. The plug the fuel pump plugs into...the blue plug with the black and grey wires? That should show voltage when the key is in the on position....right? The Volt meter reads ZERO...
I ran jumper wires to the battery off the fuel pump...ran like a charm. Now, can i run it like that? just unclamp the fuel pump from the battery when I'm not running? I know NOTHING about electrical schematics or harnesses....and really don't think I can correctly re-do a harness...or trace down why that blue plug is'nt powering the pump...there are no obvious spots along the line. Will the fuel pump burn up running directly off the battery?
