1983 115hp inline 6
bvan00
Can anyone tell me if there is usually a little play in the drive shaft after the water pump is removed?
Chris1956
Re: 1983 115hp inline 6
The driveshaft bearing is a cone-shaped one. Depending on what year of the gearcase, whether it has a preload pin, the bearing play is controlled in several ways. If the play is small, forgetaboutit
