nauticalblue
- Jul 17, 2010
- 6
Mercury 150 efi overheated now sputters while accelerating & fouling port side plugs
My 2000 Mercury 150 EFI overheated due to impeller breaking. I replaced impeller and complete poppet value assembly and engine now run cooler than ever, perhaps too cold?
The problem I'm having is during acceleration the engine sputters very badly at about 2800rpm and surges to about 3000 rpm then runs okay till it hits about 3800 rpm and it again surges to 4000 rpm. Then runs smooth from 4000 up.
I changed the plugs and fuel water separator and still have same problem. I pulled plugs and noted that all plugs on the starboard side looked good but the plugs on the port side were fouled badly especially 2 and 4.
Did compression test. All between 105 and 110. Did spark gap test all spark 7/16"
Not sure where to go next? Replace CDM modules? TPS adjustment? Engine tempeture sensor? Perhaps a stuck thermostat. Timing issue related to overheat?
Thanks in advance for your help and feedback!!
