Moe_fix_it
- Sep 3, 2011
- 13
Well I finally got the motor and all the electrical bugs fixed and working great in my 1987 211 liberator, so I decided to take it out to lake michigan and it was running great. But about a mile south of the channel on the lake the gears in the upper half of the lower unit decided they want to end there relationship. I got it home and drained the fluid from the drive and it had some tiny little speckales but no major metal shavings. Then I pulled the top cap and there was no oil or even really a trace of oil in there with the mashed up gears and chunks laying in the bottom. How do I figure out what drive ratio I have and I noticed there is a few nicks in the case so im really looking for some pointers as to what I should do and if the upper half of the case is any good and how to tear the bearings and gears off if the upper half is good.
Also wondering if there is anything I can do to make this unit a little stronger and more reliable?
Thanks!
Thanks!
