where is the shift rod pin or screw to release the rod and how to take it off?
O ottercreeksco Recruit Joined Jul 31, 2012 Messages 5 Aug 3, 2012 #1 where is the shift rod pin or screw to release the rod and how to take it off?
D Daviet Fleet Admiral Joined Sep 24, 2008 Messages 8,958 Aug 3, 2012 #2 Re: how to remove lower unit on 82 v4 82 V4 what, model number?
B boobie Supreme Mariner Joined Nov 5, 2009 Messages 20,826 Aug 3, 2012 #3 Re: how to remove lower unit on 82 v4 Go to shop.evinrude.com and bring up your mtr. Go to cyl and crank case and look for part # 66 screw. This will release the upper shift rod.
Chinewalker Fleet Admiral Joined Aug 19, 2001 Messages 8,902 Aug 4, 2012 #4 Re: how to remove lower unit on 82 v4 It's located under the bottom carb - you'll need a long screwdriver, or better yet, a 1/4-inch drive socket wrench with a long enxtension, a u-joint on the end and a 3/8" socket.
