Hi all, this is my first post! I purchased this boat about 5 years ago, the previous owner didn't take care of the boat at all. It only has 142 hours on the boat. The boat never ran good, I was always nervous when taking it out. I had someone winterize the boat for me every year till last year. When I winterized the boat, I mistakenly put anti-freeze in the intake plug. I know, stupid, right? When I started the boat this year, I had what I thought was water in the oil, so I brought the boat home with me and took it apart. The manifold was good, the Head was good so I replaced all the gaskets except the water pump and oil pan. I started the boat and ran it with ear muffs, it ran just like it did before, engine shaking, and had to pump the throttle to keep it running. I started playing with the timing, (no timing light yet) and the boat started running GREAT! It must have been off before i bought it. It starts right up and idles great, however when I start putting the rpms up, it wants to stall. I replaced the filter in the carb, The boat store didn't have the filter for the pump but said I could install an in-line filter before the pump, so I did. I've noticed the in-line filter only has gas about half way across the filter, should it be completely filled? Its installed horizontally, not vertically.
Any help would be greatly appreciated.
