justonemore3208
- Aug 3, 2012
- 1
i have a 1972 johnson 85 mod. 85esl-72r. i have had this motor since 1981. only problem i have ever had is with a power pack around 1990. my local marina put in a new one, and presto everything fine and dandy. i put the boat and motor away approx 18 years. mind you i put the boat and motor away properly. receintly i decided to re cristen the old gal. everything was clean gas lines, carb screen, plugs good. i got gas to carb and to plugs , but no fire. i couldn't get any spark. i took it to a local marina and the owner said he had much experience with this year motor, and that he tested the power pack and it was bad. new power pack $400.00 plus labor. he went on to talk about the electric solenoids in the lower unit and how many other problems this year johnson had. he offered me a 90 evenrude of 1981 vintage, of course with trim & tilt for $1500.00. anyway, i balked. is there a way to test the power pack? if it is not the power pack, then what? this johnson 85 has very little hours on it i kept it sealed up and dry for 18 years always turning the flywheel with a couple drops of good oil every few years. please help!!!!
