I am having a bit of a problem with cylinders 3 & 4. compression is good and the carb is working great. I inspected the reeds and those look good as well. If you hold your hand over the top carb you can fell it pulling in the air, but the bottom carb does not. I was having this problem last year and pulled the block apart and changed the lower seal and the spaghetti seal for the crank case. I also put on new gaskets to the head. I never had a chance to run it till the other day and same problem. I am hearing that the 3 & 4 cylinder should have a seal to keep them separate and that could be bad. Just looking for any ideas before I rip into it again.
FYI on a side note when I have the muffs on it and run it after i turn it off I get what looks like sludge coming out of 4 little holes near the lower unit, wondering if it is related or a whole other problem. Smells like gas, but feels and looks similar to grease.
Thank you for any help or ideas that get thrown my way.
