Davidwrsmith
- Jul 23, 2012
- 3
98 Johnson j200txecm the trim or tilt is not working. I bought this moror about a week ago and hung it on the transom. I straight wired the motor(blue to hot green to ground) to raise the motor to trailer it. I then lowered the motor(reversed polarity) to put the motor on the rest. I brought the boat home and have started working on it installing controls and wiring and now the trim/tilt will not work on the motor switch or control switch. And now I cant even straight wire the motor!!! When I press the down button the relay will click. Up button nothing. I replaced both relays and nothing, checked fuse and its fine. I cant imagine the trim guage switch having anything to do with it...There is some kind of switch or sensor under the motor housing above the trim motor behind the steering arm...it has 2 blue wires going into it...what is this and does it have anything to do with my problem. I am very mechanically inclined and able to troubleshoot electrical items. i cant figure out why the motor wont work when straight wired. The t/t motor ohms out fine and is not grounded.
HELP!!!!!!
This is the ONLY thing keeping me off the water!!
Thanks,
David
HELP!!!!!!
Thanks,
David
