Hello everyone...
My father in law has a medium sized but older houseboat that is powered by the 2 stroke 88 SPL and we have had some difficulties lately. I am mechanically inclined with zero boat motor experience and feel the need to step in because the mechanic he has hired has been out 3x and we are still having issues. Its expensive and I do not feel he is getting good value.
I have learned a TON already reading through everything but we only get to go out so often so I am trying to be as prepared as possible for my next visit.
It has always been temperamental starting, but then again we have NEVER used the correct start procedure I found on this forum. In fact I never knew it was a none choke motor, I assumed the switch marked choke was in fact choke. Go figure.
Is it safe to assume that starting it while activating the choke (momentary switch in this case) and full throttle can cause flooding? That seems to have been an issue with starting it in the past.
Anyway, the main question I have, is does this thing have 1 carb or 2? I have watched videos that refer to carb's, I only took the cover of the damn thing for the first time 2 weekends ago and it was not to inspect how many carbs there were.
Also is removing the carb(s) difficult, keep in mind, I will be on the water attempting this.
Now that I have read what I have read I plan to do 3 things. Should I add/remove anything from this list?
1 Start it the correct way
2 Clean out the carb or carbs, he has never winterized and it sits for a solid 8 months every year
3 Decarbonize the engine
Thanks for the great forum and all the info so far.
