I purchased my 1989 24' Grumman pontoon on July 21. The first weekend we had it out it was hard to get it started after we anchored it. We also had issues with the stereo. We'd have the radio on and about 5 minutes later the stereo would start automatically scanning channels. It even did this when I was playing music from a flash drive I had plugged in to the usb port.
Then this past weekend we took it out again. We unloaded it from the trailer and went to start it and it wouldn't start. It finally ended up draining the battery. There was a gentleman on shore that offered us to use his battery pack. So we did. It still wouldn't start and eventually drained the battery pack. The guy said we probably needed a new battery. So off to Fleet Farm I went. I got back and we put the new battery in. It started up right away. We had no problems starting it after we anchored it or beached it either. But...now none of the gauges work. Nothing. The previous weekend all the gauges worked except for the speedometer. This weekend, nothing. I should have noticed something was wrong when I went to fill up the gas tank. I turned the key on and the gauge didn't move after I had put the gas in. I just thought maybe the engine needed to be started or something but nope. After the new battery nothing works.
Any ideas??? A friend of mine had said there must be a charge issue while the engine isn't running and something is draining it. He said he would try and find all the items that needed to be grounded to make sure nothing was causing an issue that way. Also....could there be a fuse problem?? What about the stereo??
P.S. I called the previous owner and he said that he just bought the battery a year ago and it should be fine. He also said that he would charge the battery every 2-3 times he had the pontoon out. I feel that if the battery is good, then why have to charge it every 2-3 outtings?
