wineyarders
- Jun 22, 2011
- 45
5hp 2 stroke got flung off transom at FULL throttle (~10mph) as result of an unexpected and immediate 90 deg turn. So although I'm lucky it didn't knock me out, its now in about 20-40' of SALT water and I'm planning to dive and recover it from my 12' skiff in the morning (~10 hours from now). Please help with advice. From the quick searches I've done it sounds like the procedure is highly proscribed but I don't have a lot of time to search the internet or this forum. From what I've gathered I need to purge the engine with fresh water once recovered (assuming i find it), then drain, and then try and get the thing started. Do I need to pull the carb, drain the gear case oil, pull the power head, brek it open? Any thoughts. I love this engine, please help! Apologies if you see this pop up in another thread.
