I,m having a problem with my Tohatsu 25HP 4 stroke. I was running it last week at just under full power and things were fine, I increased to maximum revs and after 5 min it died. I turned it off and did not run it for an hour or so. It started ok but when going to higher revs it died again. I ran back to shore on half revs. The water pump works fine - a good stong water jet is being discharged. A mechanic has told me to check several things - change the impellor, check the thermostat etc. Does anybody know what the temp should be when the thermostat opens?
I don,t have a workshop manual- I have ordered one but it will be a few days before I receive it and I want to get on with sorting it out.
