Hello all, been reading this forum for a long time and ran into some trouble, so here I am. My brother and I bought a boat with a seized engine, and rebuilt it. When we bought the boat, nothing was hooked up, the motor was just sitting on its supports. Motor broken down, new rings, cylinders honed, head and manifold checked and trued, new gaskets all over, new water pump and this baby was ready to roll. Put her back in the boat, and she would crank but would not start. Got fuel, spark, and compression, and the issue was traced to a cracked starter solenoid. New solenoid, and she spins over like a champ, and will fire, but will not stay running.
We think our issue may be in our switch, which I am going to replace and rewire tomorrow, but I wanted someone else's opinion also. Yesterday, motor would turn over all day long at the key. New solenoid and new, heavier battery wiring today, and the key no longer works. Checked the inline fuse and it is good. When jumping the starter with a long screwdriver, she fires right up, and will run as long as you hold the screwdriver in place. But once you remove the screwdriver, it cuts out. Key is in run position as I'm doing this, so it should run, but does not. Faulty switch?
As I stated in the title, this is a 3.0 GSPHUB, 1995 model with Power steering. Boat also has Volvo SX-CT Drive. I am pretty mechanically minded. I each Volvo service manual available/applicable as shared via "Adult's Only" sticky at top. I have also read the Troubleshooting Guide by Don S., but will re-read it again tonight to verify I have checked everything.
